ENGINE:
KA24DE-T
ENGINE MODS
SuperTech 9:1 forged pistons (.89mm bore)
Crower Cams
Clevite Mand and Rod Bearings
ARP Main Stud Kit
New OEM timing chain assemblies
SuperTech valves
SuperTech Dual springs w/ titanium retainers
S13 Cams
O-ring block deck surface
5 angle valve job
Turbo System:
Garrett T04e 50 trim
AMS tubular bottom mount t3 header
TiAL 44mm waste gate
Custom waste gate dump tube
Custom Down pipe
JGS oil feed and return
FMIC 24x12x3
Custom IC piping
Apex-i Dual N1 exhaust
Engine Management:
XAT Racing Rom Tune ECU
APEXi SAFC controller
Autometer Guages
Fuel System:
JGY Fuel Rail
Walbro 255 fuel pump
75lb injectors
Aero motive FPR
300zx TT fuel filter
JGS Resistor pack
Fuel pressure gauge
Ignition:
Taylor Wires
NGK BKR7E
MSD 6al Coil
Optima Battery
Cooling System:
Koyo Radiator
Nismo Thermostat
Flex-a-lite Fans
Blitz Radiator cap
Driveline:
Stock KA transmission
Competition Stage 4 clutch
Infiniti J30 vlsd
Wheels/Tires/Suspension:
Sport Max 002 16×8 0 offset
Falken Azenis 255/50R16
KYB Adjustable struts
RSR lowering springs
Tein Tension Rods
Tein Inner & Outter Rods
Nismo Steering rack Bushings
This is my first car that I purchased back in November of 2004 coming out of high school. I purchased this car after saving money for 2 years working at a Vertical Blind business at minimum wage so there is definately a lot of effort put into the upgrades.
When I first brought the car, I had a vision of what a 240sx should look like. I wanted the “Clean†look as people walk by the car. At the time, SR20 swaps were starting to get very popular and theNissan 240sx community mostly considered these swaps werethe only way to go as far as power goes. I didn’t want to join the SR20 bandwagon, so I turned to the KA-T. The decision at the time was frowned upon in the 240 community as the KA was (and still is somewhat)considered a generic “truck Motor” and not worthy of its place in a upgraded 240sx. I wanted to be different and prove to the local SR guys that a KA has lots of potential.I believe I have provenmy point.
My vision looked far away from completion but 4 years later, it turn from a vision to real life……
