Fog Light Modification By:NISTECH NOTE:This is for a Pathfinder / QX4, but MAY be adaptable to other Nissan models as well. The fog lamp relay is powered through the headlamp relay, so your headlights would need to be on to power the fog lamp relay. The ground side of the relay goes through the foglamp […]
Q45 Fog Light Modification
Fog Light Modification Infiniti Fourth Generation Q45 Wiring Relays Tools Electrical Battery Cable Yellow Customize Personal Soldering Wire Taps Crimping Splicing Strippers Connectors Bundle Cut Strip Shock Short Jumper I thought I had done this already, but could not find it. I am doing it over due to requests I keep getting of how to […]
