Changing trans oil on a G35 6MT: NOTE:Do NOT use GL5 transmission fluid. It will damage the synchros in the Nissan transmission. You need GL4 fluid. Most fluid you buy at autoparts stores is GL5. I recommend a mixture of 2 quarts Redline MTL (70W-80) and 2 quarts Redline MT-90 (75W-90), as Nissan calls for […]
240sx 5-speed swap tutorial
240sx 5-Speed Manual Transmission Swap: A Tutorial In this writeup, two different cars were having the conversion done simultaneously. One is Matt’s ’98 starfire blue S14, the other is my ’97 cobalt green S14. The procedure was basically the same for both cars, and some pictures may jump from one car to the other. The […]
2004 Nissan 350Z – NICOclub Ride of the Month September 2005
ATI ProCharger w/ 9psi pully Shielded CAS wire Custom Grounding Kit AAM Y Pipe High flow Cats J&S Ultra Safeguard AAM ECU reflash B&M Short Shift Kit GReddy AirFlow Plate EGT Gauge in Drivers door AC vent Plenum Spacer Greddy Oil Catch Can Koni 8241 adjustable shocks Greddy Blowoff Valve 2004 Nissan 350Z – Owned […]
