Resolving Rough IdleBy Jesda Gulati Fuel Injectors – Bad gas or regional mixtures tend to result inearly injector failures. A fuel smell in the cabin also hintsat injector problems. Non-OEM injectors are not recommended.Learn how to test your injectors Fuel System- Purchase a can of BG44kfrom Infiniti of Scottsdale and add it to a 3/4 […]
1997-2001 Q45 O2 Sensor Replacement
Y33 O2 Sensor Replacement By:bullittandy Just finished the O2 sensors (all 4) on my 97 Q45. Here’s a heads up for others attempting the job. WD-40 / PB Blaster MUST be used! Don’t try to do anything until the sensor nuts have soaked for at least 30 minutes but the longer the better (I soaked […]
