Items Needed: -Ratchet with 10mm, 12mm, & 14mm sockets and an extension (I used a 3″)-2-3 ft cheater bar (You will NEED this unless you have a long handle ratchet)-Latex Gloves (optional)-2 Drive Belts (power steering/Alternator and A/C) Access First off, remove the intake scoop. Now remove the under body covering. This is the most […]
How to: Modifying a S13 240SX steering rack for manual steering
From the factory, the Nissan 240SX came with hydraulically assisted power steering. For a street car this is a tried and true system. That being said, many people, for different reasons, choose to dispatch with the power assist. The power steering system consists of three main parts, namely the pump, the lines, and the steering […]
