First you have to pull away the trunk wall carpeting from its original position near the tail light. You do this by simply finding where its carpet edges meet the car body near the top of the trunk bowl and pulling on it. However once you get near the inside you can see theres a […]
Custom Tint on Maxima tail lights
1. Remove tail lights by pulling back the trunk liner, after removing the retaining clips, and tail light housing nuts, on the inside of trunk. You may have to push your lenses out from inside the trunk with your hand because of the weather seal on the back side of it. If you get the […]
Altima Coupe Painting Taillights
In this article we will be painting a set a Altima Coupe taillights. This is an alternative to using vinyl overlays as it is easier to apply and slightly more permanent. Note: Check with your local jurisdiction before performing this as it may not be legal in all states. Skill Level 1 of 5 Time […]
