1990 240SX Capacities and Specifications
    Refill capacities for engine model KA24E
    Fuel tank 15 7/8 gallons
    Coolant (with reservoir tank) 7 1/8 quarts
    Engine oil without filter 3 3/8 quarts
    Engine oil with filter 3 3/4 quarts
    Transmission fluid
    manual transmission (M/T) 5 1/8 pints
    automatic transmission (A/T) 8 3/4 quarts
    Differential Carrier (R200) 3 7/8 pints
    Power steering system 1.0 quart
    Air conditioning refrigerant 2.0 – 2.2 lb
    Engine Tune Up Data:
    Engine model KA24E
    Firing Order 1-3-4-2
    Idle speed M/T 750 +/- 50 rpm
    Idle speed A/T 750 +/- 50 rpm
    Ignition timing 15 degree = +/- 2 degree B.T.D.C. at idle speed
    Idle “CO” Idle mixture screw is preset and sealed at factory
    Valve clearance “hot” Non adjustable
    High tension cable resistance less than 30 kilo ohms
    Spark Plug Type
    standard ZFR5E-11
    hot ZFR4E-11
    cold ZFR6E-11
    gap mm (in) 1.0-1.1 (0.039-0.043)
    tightening torque
    N-m 20-29
    kg-m 2.0-3.0
    ft-lb 14-22
    Drive belt deflection (cold) all belt measurements in millimeters with
    inches in parenthesis
    alternator 11 (0.43) limit
    deflection after adjustment 7-8 (0.28-0.31)
    deflection of new belt 6-7 ( 0.24-0.28)
    Air conditioner compressor
    limit 12 (0.47)
    Power steering pump
    limit 13 (0.51)
    deflection after adjustment 8-9 ( 0.31- 0.35)
    deflection of new belt 7-8 (0.28- 0.31)
    Applied pressed force N (kg, lb) 98 (10, 22)
    Oil pan tightening torque
    N-m 29-39
    kg-m 3.0-4.0
    ft-lb 22-29
    Clutch pedal height mm (in) 18-196 ( 7.32- 7.72)
    Clutch pedal free play mm (in) 1-3 ( 0.04- 0.12)
    Front wheel alignment (unladen) fuel, radiator and engine oil full with
    spare tire, jack, and tools.
    camber -1 degree 30′ to 0 degree
    caster 6 degree 00′ to 7 degree 30′
    toe in mm (in) 0.3 – 2.3 (0.012 – 0.091)
    toe in degree 2′ – 13′ ( total toe in angle)
    Full turns inner wheel 39 degree – 43 degree
    Full turns outer wheel 33 degree
    Rear wheel alignment (unladen) as above
    camber -1 degree 30′ to -0 degree 36′
    toe in mm (in) 0.5- 4.5 (0.020- 0.177)
    toe in degree 3′ – 25′ (total toe in angle)
    Brake
    pad repair limit mm (in) 2.0 ( 0.079)
    front rotor thickness limit 18.0 (0.709) mm (in)
    rear rotor thickness limit 8.0 (0.315) mm (in)
    pedal free height M/T 177- 187 (6.97 – 7.36) mm (in)
    pedal free height A/T 186- 196 (7.32 – 7.72) mm (in)
    parking brake # of notches 6-8
    Engine Compression in PSI
    standard 192 @ 300rpm
    minimum 142 @ 300 rpm
    difference limit between cylinders 14 @ 300rpm
    Thermostat inspection
    valve opening temperature 170 degree fahrenheit
    maximum valve lift 0.31 inches @ 194 degree fahrenheit
    Oil pressure check
    idle speed at 3000 rpm no load 60-70 PSI
    Radiator cap relief pressure 11-14 psi
    leakage test pressure 14 psi
    Filed Under: 240sx Articles
