If you want to be JDM tyte with some rare-ish bling, you need some power folding mirrors from a Silvia. Designed so you can fit your car into tight spots without worrying about having them knocked off, these mirrors are only marginally less useful in the US where most people in parking lots disregard the lines between spots or generally drive like drunken, hormone-frenzied idiots that they are.
Difficulty: **
Time: 2-4 hours
Cost: check with importers
Materials:
- JDM Power Folding Mirrors
- wire splices
Tools:
- Phillips head screwdriver
- Flathead screwdriver
- Socket wrenches
- Wire cutters
Procedure:
This is a write-up on how to install power folding mirriors on a S14. I made this write-up in 30 diffferent parts and as clear as I could but if I made any mistakes or anything please let me know, thanks.
Part 01: Remove the screw that is circled below:
Part 02: Now just use a flathead screwdriver and pry it open.
Part 03: This is what it looks like once you have removed it:
Part 04: Remove the screw that is circled below:
Part 05: Now just pull it out.
Part 06: This is what it looks like once you have removed it:
Part 07: Remove the following 3 screws that are circled below:
Part 08: Now pull the door panel off.
Part 09: This is what it looks like once you have removed it:
Part 10: Now just use a flathead screwdriver and pry it open.
Part 11: Remove the following 3 screws that are circled below:
Part 12: Now disconnect the following:
Part 13: This is what it looks like once you have removed it:
Part 14: This is what it looks like once you have removed it:
Part 15: Remove the following 3 screws that are circled below:
Part 16: Now just use a flathead screwdriver and pry it open.
Part 17: Remove the screw that is circled below:
Part 18: Now remove the following 4 screws that are circled below:
Part 19: Remove the screw that is circled below:
Part 20: Now take a wire cutter and cut the following 3 wires:
Part 21: This is what it looks like once you have cut it:
Part 22: Now just pull on the wire until it comes out.
Part 23: This is what it looks like once you have removed it:
Part 24: Now just connect the following wires:
Part 25: This is what it looks like when you haved connected the wires:
Part 26: Now connect the following:
Part 27: The following is the JDM switch and adapter:
Part 28, Step 01: Connect the wires from the mirrors to this using the wiring diagram below:
Part 28, Step 02: The following is the wiring diagram:
Purple/White to Purple/White
Blue/White to Blue/Black
Black to Black
Blue/Red to Blue/Red
Yellow/Black to Yellow/Red
Orange to Orange/Silver
Yellow/Green to Yellow/Green
Part 29: Just for reference:
Part 30: Just for reference:
