Neverlift’s DIY Drift Brake Knob!
by neverlift
Overview:
This is a cheap and simple mod designed to save people the $10-$20 they would otherwise be spending on a “drift knob” that cost less than $1 to manufacture.
Difficulty: **
Time: 1 hour
Cost: Free
Tools:
- drill with small bit
- flathead screwdriver
- pliers(optional)
Materials:
- keyring or a piece of solid wire\
Procedure:
first remove e-brake cover
second use flathead to bend tabs that hold spring in place(optional, remove spring with pliers)
third reinstall e-brake cover
fourth use drill/bit to drill a SMALL hole in the thumb knob, careful not too high and not too low
fifth install keyring or whatever thru knob
last put up tools,go for a drive and test.
good luck
