This DIY will show you how to remove the Stereo/CD/Radio unit and the Climate Controls out of your G35.
Tools Needed:
Small Flathead Screwdriver
Phillips Screwdriver
Cup or Tray to collect screws (Optional)
Step 1: Unclip trim at base of shifter. Push down to release.
Step 2:Remove gold C clip from shift knob.
Step 3:Unclip bezel around shifter and cupholders.
Step 4:Remove 2 gold screws below radio.
Step 5:Using a small screwdriver, Unclip bezel around clock and display.Pull straight to release.
Step 6:Remove 2 screws holding clock to dash.
Step 7: Remove gold screw behind clock.
Step 8:Remove 4 screws securing glovebox to car.Push straight down to unclip glovebox.
Step 9:Remove 2 screws securing console side panel.
Step 10:Unclip panel.
Step 11: Remove gold screw under hood release.
Step 12:Unclip panel under steering column.
Step 13:Remove 2 screws securing drivers side panel.
Step 14:Unclip center console side panel.
Remove radio and AC controls from dash.Separate radio body from AC controls and vents.
