How to Extract a DTC Code from your Versa
January 3, 2010 by Greg
Today, while driving the Versa of my girlfriend, a check engine light pops up right in my face. So, in the past I had troubles with check engine lights on my SpecV and there was a procedure for a self-diagnostic mode using gas pedal and the key in the ignition. So I tried it, it does work on the Versa too. So there it is, hope it helps other Versa owners on the board.:
In car ECM Diagnostics/ECM Reset procedure:
1) Sit in the driver’s seat.2) Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)3) Fully depress and release the accelerator pedal five times in less than five seconds.4) Wait exactly seven seconds. Fully depress the accelerator pedal for ten seconds until the MIL light flashes.5) Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.
Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.)The next three digits follow in turn in the same fashion except with faster blinks (0.3 second) and a 1.0-second pause between digits.
The ECM code repeats intself until you turn the ignition key to the OFF position, at which point the ECM resets itself to standard get-in-and-drive-the-car mode.You can look up the trouble codes in the ESM/FSM; there’s a bunch of them. In the ESM, refer to page EC-639.Additionally, if you get four blinks of ten (0000), the ECM is indicating no malfunction.
You can clear the code (and the annoying MIL) by holding down the accelerator pedal for more than 10 seconds while in Diagnostic Test Mode II. When you release the pedal, the ECM erases the trouble code(s).
Have a watch with yourself, it helps a lot.
List of check engine code:
P0031 Front oxygen (A/F) sensor heater circuit low inputP0032 Front oxygen (A/F) sensor heater circult high inputP0037 Rear oxygen sensor heater circuit malfunctionP0038 Rear oxygen sensor heater circuit high inputP0065 Air assist injector solenoid valve malfunctionP0066 Air assist injector solenoid valve circuit low inputP0067 Air assist injector solenoid valve circuit high inputP0100 Mass or Volume Air Flow Circuit MalfunctionP0101 Mass or Volume Air Flow Circuit Range/Performance ProblemP0102 Mass or Volume Air Flow Circuit Low InputP0103 Mass or Volume Air Flow Circuit High InputP0104 Mass or Volume Air Flow Circuit IntermittentP0105 Manifold Absolute Pressure/Barometric Pressure Circuit MalfunctionP0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance ProblemP0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low InputP0108 Manifold Absolute Pressure/Barometric Pressure Circuit High InputP0109 Manifold Absolute Pressure/Barometric Pressure Circuit IntermittentP0110 Intake Air Temperature Circuit MalfunctionP0111 Intake Air Temperature Circuit Range/Performance ProblemP0112 Intake Air Temperature Circuit Low InputP0113 Intake Air Temperature Circuit High InputP0114 Intake Air Temperature Circuit IntermittentP0115 Engine Coolant Temperature Circuit MalfunctionP0116 Engine Coolant Temperature Circuit Range/Performance ProblemP0117 Engine Coolant Temperature Circuit Low InputP0118 Engine Coolant Temperature Circuit High InputP0119 Engine Coolant Temperature Circuit IntermittentP0120 Throttle/Petal Position Sensor/Switch A Circuit MalfunctionP0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance ProblemP0122 Throttle/Petal Position Sensor/Switch A Circuit Low InputP0123 Throttle/Petal Position Sensor/Switch A Circuit High InputP0124 Throttle/Petal Position Sensor/Switch A Circuit IntermittentP0125 Insufficient Coolant Temperature for Closed Loop Fuel ControlP0126 Insufficient Coolant Temperature for Stable OperationP0128 Thermostat malfunctionP0130 O2 Sensor Circuit Range/Performance Problem – Malfunction (Bank 1 Sensor 1)P0131 O2 Sensor Circuit Range/Performance Problem – Low Input (Bank 1 Sensor 1)P0132 O2 Sensor Circuit Range/Performance Problem – High Input (Bank 1 Sensor 1)P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)P0136 O2 Sensor Circuit Range/Performance Problem – Malfunction (Bank 1 Sensor 2)P0137 O2 Sensor Circuit Range/Performance Problem – Low Input (Bank 1 Sensor 2)P0138 O2 Sensor Circuit Range/Performance Problem – High Input (Bank 1 Sensor 2)P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)P0142 O2 Sensor Circuit Range/Performance Problem – Malfunction (Bank 1 Sensor 3)P0143 O2 Sensor Circuit Range/Performance Problem – Low Input (Bank 1 Sensor 3)P0144 O2 Sensor Circuit Range/Performance Problem – High Input (Bank 1 Sensor 3)P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)P0150 O2 Sensor Circuit Range/Performance Problem – Malfunction (Bank 2 Sensor 1)P0151 O2 Sensor Circuit Range/Performance Problem – Low Input (Bank 2 Sensor 1)P0152 O2 Sensor Circuit Range/Performance Problem – High Input (Bank 2 Sensor 1)P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)P0156 O2 Sensor Circuit Range/Performance Problem – Malfunction (Bank 2 Sensor 2)P0157 O2 Sensor Circuit Range/Performance Problem – Low Input (Bank 2 Sensor 2)P0158 O2 Sensor Circuit Range/Performance Problem – High Input (Bank 2 Sensor 2)P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)P0162 O2 Sensor Circuit Range/Performance Problem – Malfunction (Bank 2 Sensor 3)P0163 O2 Sensor Circuit Range/Performance Problem – Low Input (Bank 2 Sensor 3)P0164 O2 Sensor Circuit Range/Performance Problem – High Input (Bank 2 Sensor 3)P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)P0170 Fuel Trim Malfunction (Bank 1)P0171 System too Lean (Bank 1)P0172 System too Rich (Bank 1)P0173 Fuel Trim Malfunction (Bank 2)P0174 System too Lean (Bank 2)P0175 System too Rich (Bank 2)P0176 Fuel Composition Sensor Circuit MalfunctionP0177 Fuel Composition Sensor Circuit Range/PerformanceP0178 Fuel Composition Sensor Circuit Low InputP0179 Fuel Composition Sensor Circuit High InputP0180 Fuel Temperature Sensor A Circuit MalfunctionP0181 Fuel Temperature Sensor A Circuit Range/PerformanceP0182 Fuel Temperature Sensor A Circuit Low InputP0183 Fuel Temperature Sensor A Circuit High InputP0184 Fuel Temperature Sensor A Circuit IntermittentP0185 Fuel Temperature Sensor B Circuit MalfunctionP0186 Fuel Temperature Sensor B Circuit Range/PerformanceP0187 Fuel Temperature Sensor B Circuit Low InputP0188 Fuel Temperature Sensor B Circuit High InputP0189 Fuel Temperature Sensor B Circuit IntermittentP0190 Fuel Rail Pressure Sensor Circuit MalfunctionP0191 Fuel Rail Pressure Sensor Circuit Range/PerformanceP0192 Fuel Rail Pressure Sensor Circuit Low InputP0193 Fuel Rail Pressure Sensor Circuit High InputP0194 Fuel Rail Pressure Sensor Circuit IntermittentP0195 Engine Oil Temperature Sensor MalfunctionP0196 Engine Oil Temperature Sensor Range/PerformanceP0197 Engine Oil Temperature Sensor LowP0198 Engine Oil Temperature Sensor HighP0199 Engine Oil Temperature Sensor IntermittentP0200 Injector Circuit MalfunctionP0201 Injector Circuit Malfunction – Cylinder 1P0202 Injector Circuit Malfunction – Cylinder 2P0203 Injector Circuit Malfunction – Cylinder 3P0204 Injector Circuit Malfunction – Cylinder 4P0205 Injector Circuit Malfunction – Cylinder 5P0206 Injector Circuit Malfunction – Cylinder 6P0207 Injector Circuit Malfunction – Cylinder 7P0208 Injector Circuit Malfunction – Cylinder 8P0209 Injector Circuit Malfunction – Cylinder 9P0210 Injector Circuit Malfunction – Cylinder 10P0211 Injector Circuit Malfunction – Cylinder 11P0212 Injector Circuit Malfunction – Cylinder 12P0213 Cold Start Injector 1 MalfunctionP0214 Cold Start Injector 2 MalfunctionP0215 Engine Shutoff Solenoid MalfunctionP0216 Injection Timing Control Circuit MalfunctionP0217 Engine Overtemp ConditionP0218 Transmission Over Temperature ConditionP0219 Engine Overspeed ConditionP0220 Throttle/Petal Position Sensor/Switch B Circuit MalfunctionP0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance ProblemP0222 Throttle/Petal Position Sensor/Switch B Circuit Low InputP0223 Throttle/Petal Position Sensor/Switch B Circuit High InputP0224 Throttle/Petal Position Sensor/Switch B Circuit IntermittentP0225 Throttle/Petal Position Sensor/Switch C Circuit MalfunctionP0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance ProblemP0227 Throttle/Petal Position Sensor/Switch C Circuit Low InputP0228 Throttle/Petal Position Sensor/Switch C Circuit High InputP0229 Throttle/Petal Position Sensor/Switch C Circuit IntermittentP0230 Fuel Pump Primary Circuit MalfunctionP0231 Fuel Pump Secondary Circuit LowP0232 Fuel Pump Secondary Circuit HighP0233 Fuel Pump Secondary Circuit IntermittentP0234 Engine Overboost ConditionP0235 Turbocharger Boost Sensor A Circuit MalfunctionP0236 Turbocharger Boost Sensor A Circuit Range/PerformanceP0237 Turbocharger Boost Sensor A Circuit LowP0238 Turbocharger Boost Sensor A Circuit HighP0239 Turbocharger Boost Sensor B MalfunctionP0240 Turbocharger Boost Sensor B Circuit Range/PerformanceP0241 Turbocharger Boost Sensor B Circuit LowP0242 Turbocharger Boost Sensor B Circuit HighP0243 Turbocharger Wastegate Solenoid A MalfunctionP0244 Turbocharger Wastegate Solenoid A Range/PerformanceP0245 Turbocharger Wastegate Solenoid A LowP0246 Turbocharger Wastegate Solenoid A HighP0247 Turbocharger Wastegate Solenoid B MalfunctionP0248 Turbocharger Wastegate Solenoid B Range/PerformanceP0249 Turbocharger Wastegate Solenoid B LowP0250 Turbocharger Wastegate Solenoid B HighP0251 Injection Pump Fuel Metering Control “A” Malfunction (Cam/Rotor/Injector)P0252 Injection Pump Fuel Metering Control “A” Range/Performance (Cam/Rotor/Injector)P0253 Injection Pump Fuel Metering Control “A” Low (Cam/Rotor/Injector)P0254 Injection Pump Fuel Metering Control “A” High (Cam/Rotor/Injector)P0255 Injection Pump Fuel Metering Control “A” Intermittent (Cam/Rotor/Injector)P0256 Injection Pump Fuel Metering Control “B” Malfunction (Cam/Rotor/Injector)P0257 Injection Pump Fuel Metering Control “B” Range/Performance (Cam/Rotor/Injector)P0258 Injection Pump Fuel Metering Control “B” Low (Cam/Rotor/Injector)P0259 Injection Pump Fuel Metering Control “B” High (Cam/Rotor/Injector)P0260 Injection Pump Fuel Metering Control “B” Intermittent (Cam/Rotor/Injector)P0261 Cylinder 1 Injector Circuit LowP0262 Cylinder 1 Injector Circuit HighP0263 Cylinder 1 Contribution/Balance FaultP0264 Cylinder 2 Injector Circuit LowP0265 Cylinder 2 Injector Circuit HighP0266 Cylinder 2 Contribution/Balance FaultP0267 Cylinder 3 Injector Circuit LowP0268 Cylinder 3 Injector Circuit HighP0269 Cylinder 3 Contribution/Balance FaultP0270 Cylinder 4 Injector Circuit LowP0271 Cylinder 4 Injector Circuit HighP0272 Cylinder 4 Contribution/Balance FaultP0273 Cylinder 5 Injector Circuit LowP0274 Cylinder 5 Injector Circuit HighP0275 Cylinder 5 Contribution/Balance FaultP0276 Cylinder 6 Injector Circuit LowP0277 Cylinder 6 Injector Circuit HighP0278 Cylinder 6 Contribution/Balance FaultP0279 Cylinder 7 Injector Circuit LowP0280 Cylinder 7 Injector Circuit HighP0281 Cylinder 7 Contribution/Balance FaultP0282 Cylinder 8 Injector Circuit LowP0283 Cylinder 8 Injector Circuit HighP0284 Cylinder 8 Contribution/Balance FaultP0285 Cylinder 9 Injector Circuit LowP0286 Cylinder 9 Injector Circuit HighP0287 Cylinder 9 Contribution/Balance FaultP0288 Cylinder 10 Injector Circuit LowP0289 Cylinder 10 Injector Circuit HighP0290 Cylinder 10 Contribution/Balance FaultP0291 Cylinder 11 Injector Circuit LowP0292 Cylinder 11 Injector Circuit HighP0293 Cylinder 11 Contribution/Balance FaultP0294 Cylinder 12 Injector Circuit LowP0295 Cylinder 12 Injector Circuit HighP0296 Cylinder 12 Contribution/Range FaultP0300 Random/Multiple Cylinder Misfire DetectedP0301 Cylinder 1 Misfire DetectedP0302 Cylinder 2 Misfire DetectedP0303 Cylinder 3 Misfire DetectedP0304 Cylinder 4 Misfire DetectedP0305 Cylinder 5 Misfire DetectedP0306 Cylinder 6 Misfire DetectedP0307 Cylinder 7 Misfire DetectedP0308 Cylinder 8 Misfire DetectedP0309 Cylinder 9 Misfire DetectedP0310 Cylinder 10 Misfire DetectedP0311 Cylinder 11 Misfire DetectedP0312 Cylinder 12 Misfire DetectedP0320 Ignition/Distributor Engine Speed Input Circuit MalfunctionP0321 Ignition/Distributor Engine Speed Input Circuit Range/PerformanceP0322 Ignition/Distributor Engine Speed Input Circuit No SignalP0323 Ignition/Distributor Engine Speed Input Circuit IntermittentP0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)P0332 Knock Sensor 2 Circuit Low Input (Bank 2)P0333 Knock Sensor 2 Circuit High Input (Bank 2)P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)P0335 Crankshaft Position Sensor A Circuit MalfunctionP0336 Crankshaft Position Sensor A Circuit Range/PerformanceP0337 Crankshaft Position Sensor A Circuit Low InputP0338 Crankshaft Position Sensor A Circuit High InputP0339 Crankshaft Position Sensor A Circuit IntermittentP0340 Camshaft Position Sensor Circuit MalfunctionP0341 Camshaft Position Sensor Circuit Range/PerformanceP0342 Camshaft Position Sensor Circuit Low InputP0343 Camshaft Position Sensor Circuit High InputP0344 Camshaft Position Sensor Circuit IntermittentP0350 Ignition Coil Primary/Secondary Circuit MalfunctionP0351 Ignition Coil A Primary/Secondary Circuit MalfunctionP0352 Ignition Coil B Primary/Secondary Circuit MalfunctionP0353 Ignition Coil C Primary/Secondary Circuit MalfunctionP0354 Ignition Coil D Primary/Secondary Circuit MalfunctionP0355 Ignition Coil E Primary/Secondary Circuit MalfunctionP0356 Ignition Coil F Primary/Secondary Circuit MalfunctionP0357 Ignition Coil G Primary/Secondary Circuit MalfunctionP0358 Ignition Coil H Primary/Secondary Circuit MalfunctionP0359 Ignition Coil I Primary/Secondary Circuit MalfunctionP0360 Ignition Coil J Primary/Secondary Circuit MalfunctionP0361 Ignition Coil K Primary/Secondary Circuit MalfunctionP0362 Ignition Coil L Primary/Secondary Circuit MalfunctionP0370 Timing Reference High Resolution Signal A MalfunctionP0371 Timing Reference High Resolution Signal A Too Many PulsesP0372 Timing Reference High Resolution Signal A Too Few PulsesP0373 Timing Reference High Resolution Signal A Intermittent/Erratic PulsesP0374 Timing Reference High Resolution Signal A No PulsesP0375 Timing Reference High Resolution Signal B MalfunctionP0376 Timing Reference High Resolution Signal B Too Many PulsesP0377 Timing Reference High Resolution Signal B Too Few PulsesP0378 Timing Reference High Resolution Signal B Intermittent/Erratic PulsesP0379 Timing Reference High Resolution Signal B No PulsesP0380 Glow Plug/Heater Circuit “A” MalfunctionP0381 Glow Plug/Heater Indicator Circuit MalfunctionP0382 Exhaust Gas Recirculation Flow MalfunctionP0385 Crankshaft Position Sensor B Circuit MalfunctionP0386 Crankshaft Position Sensor B Circuit Range/PerformanceP0387 Crankshaft Position Sensor B Circuit Low InputP0388 Crankshaft Position Sensor B Circuit High InputP0389 Crankshaft Position Sensor B Circuit IntermittentP0400 Exhaust Gas Recirculation Flow MalfunctionP0401 Exhaust Gas Recirculation Flow Insufficient DetectedP0402 Exhaust Gas Recirculation Flow Excessive DetectedP0403 Exhaust Gas Recirculation Circuit MalfunctionP0404 Exhaust Gas Recirculation Circuit Range/PerformanceP0405 Exhaust Gas Recirculation Sensor A Circuit LowP0406 Exhaust Gas Recirculation Sensor A Circuit HighP0407 Exhaust Gas Recirculation Sensor B Circuit LowP0408 Exhaust Gas Recirculation Sensor B Circuit HighP0410 Secondary Air Injection System MalfunctionP0411 Secondary Air Injection System Incorrect Flow DetectedP0412 Secondary Air Injection System Switching Valve A Circuit MalfunctionP0413 Secondary Air Injection System Switching Valve A Circuit OpenP0414 Secondary Air Injection System Switching Valve A Circuit ShortedP0415 Secondary Air Injection System Switching Valve B Circuit MalfunctionP0416 Secondary Air Injection System Switching Valve B Circuit OpenP0417 Secondary Air Injection System Switching Valve B Circuit ShortedP0418 Secondary Air Injection System Relay “A” Circuit MalfunctionP0419 Secondary Air Injection System Relay “B” Circuit MalfunctionP0420 Catalyst System Efficiency Below Threshold (Bank 1)P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)P0422 Main Catalyst Efficiency Below Threshold (Bank 1)P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)P0424 Heated Catalyst Temperature Below Threshold (Bank 1)P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)P0427 Catalyst Temperature Sensor Low Input (Bank 1)P0428 Catalyst Temperature Sensor High Input (Bank 1)P0430 Catalyst System Efficiency Below Threshold (Bank 2)P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)P0432 Main Catalyst Efficiency Below Threshold (Bank 2)P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)P0434 Heated Catalyst Temperature Below Threshold (Bank 2)P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)P0437 Catalyst Temperature Sensor Low Input (Bank 2)P0438 Catalyst Temperature Sensor High Input (Bank 2)P0440 Evaporative Emission Control System MalfunctionP0441 Evaporative Emission Control System Incorrect Purge FlowP0442 Evaporative Emission Control System Leak Detected (small leak)P0443 Evaporative Emission Control System Purge Control Valve Circuit MalfunctionP0444 Evaporative Emission Control System Purge Control Valve Circuit OpenP0445 Evaporative Emission Control System Purge Control Valve Circuit ShortedP0446 Evaporative Emission Control System Vent Control Circuit MalfunctionP0447 Evaporative Emission Control System Vent Control Circuit OpenP0448 Evaporative Emission Control System Vent Control Circuit ShortedP0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit MalfunctionP0450 Evaporative Emission Control System Pressure Sensor MalfunctionP0451 Evaporative Emission Control System Pressure Sensor Range/PerformanceP0452 Evaporative Emission Control System Pressure Sensor Low InputP0453 Evaporative Emission Control System Pressure Sensor High InputP0454 Evaporative Emission Control System Pressure Sensor IntermittentP0455 Evaporative Emission Control System Leak Detected (gross leak)P0456 Evaporative emission control system malfunctionP0457 Evaporative Emission Control System Leak Detected (gross leak)P0460 Fuel Level Sensor Circuit MalfunctionP0461 Fuel Level Sensor Circuit Range/PerformanceP0462 Fuel Level Sensor Circuit Low InputP0463 Fuel Level Sensor Circuit High InputP0464 Fuel Level Sensor Circuit IntermittentP0465 Purge Flow Sensor Circuit MalfunctionP0466 Purge Flow Sensor Circuit Range/PerformanceP0467 Purge Flow Sensor Circuit Low InputP0468 Purge Flow Sensor Circuit High InputP0469 Purge Flow Sensor Circuit IntermittentP0470 Exhaust Pressure Sensor MalfunctionP0471 Exhaust Pressure Sensor Range/PerformanceP0472 Exhaust Pressure Sensor LowP0473 Exhaust Pressure Sensor HighP0474 Exhaust Pressure Sensor IntermittentP0475 Exhaust Pressure Control Valve MalfunctionP0476 Exhaust Pressure Control Valve Range/PerformanceP0477 Exhaust Pressure Control Valve LowP0478 Exhaust Pressure Control Valve HighP0479 Exhaust Pressure Control Valve IntermittentP0480 Cooling Fan 1 Control Circuit MalfunctionP0481 Cooling Fan 2 Control Circuit MalfunctionP0482 Cooling Fan 3 Control Circuit MalfunctionP0483 Cooling Fan Rationality Check MalfunctionP0484 Cooling Fan Circuit Over CurrentP0485 Cooling Fan Power/Ground Circuit MalfunctionP0500 Vehicle Speed Sensor MalfunctionP0501 Vehicle Speed Sensor Range/PerformanceP0502 Vehicle Speed Sensor Low InputP0503 Vehicle Speed Sensor Intermittent/Erratic/HighP0505 Idle Control System MalfunctionP0506 Idle Control System RPM Lower Than ExpectedP0507 Idle Control System RPM Higher Than ExpectedP0508 Idle control system circuit low inputP0509 Idle control system circuit high inputP0510 Closed Throttle Position Switch MalfunctionP0512 Starter switch circuit high inputP0520 Engine Oil Pressure Sensor/Switch Circuit MalfunctionP0521 Engine Oil Pressure Sensor/Switch Circuit Range/PerformanceP0522 Engine Oil Pressure Sensor/Switch Circuit Low VoltageP0523 Engine Oil Pressure Sensor/Switch Circuit High VoltageP0530 A/C Refrigerant Pressure Sensor Circuit MalfunctionP0531 A/C Refrigerant Pressure Sensor Circuit Range/PerformanceP0532 A/C Refrigerant Pressure Sensor Circuit Low InputP0533 A/C Refrigerant Pressure Sensor Circuit High InputP0534 Air Conditioner Refrigerant Charge LossP0545 Exhaust gas temperature sensor circuit low inputP0546 Exhaust gas temperature sensor circult high inputP0550 Power Steering Pressure Sensor Circuit MalfunctionP0551 Power Steering Pressure Sensor Circuit Range/PerformanceP0552 Power Steering Pressure Sensor Circuit Low InputP0553 Power Steering Pressure Sensor Circuit High InputP0554 Power Steering Pressure Sensor Circuit IntermittentP0560 System Voltage MalfunctionP0561 System Voltage UnstableP0562 System Voltage LowP0563 System Voltage HighP0565 Cruise Control On Signal MalfunctionP0566 Cruise Control Off Signal MalfunctionP0567 Cruise Control Resume Signal MalfunctionP0568 Cruise Control Set Signal MalfunctionP0569 Cruise Control Coast Signal MalfunctionP0570 Cruise Control Accel Signal MalfunctionP0571 Cruise Control/Brake Switch A Circuit MalfunctionP0572 Cruise Control/Brake Switch A Circuit LowP0573 Cruise Control/Brake Switch A Circuit HighP0574 Cruise Control Related MalfunctionP0575 Cruise Control Related MalfunctionP0576 Cruise Control Related MalfunctionP0576 Cruise Control Related MalfunctionP0578 Cruise Control Related MalfunctionP0579 Cruise Control Related MalfunctionP0580 Cruise Control Related MalfunctionP0600 Serial Communication Link MalfunctionP0601 Internal Control Module Memory Check Sum ErrorP0602 Control Module Programming ErrorP0603 Internal Control Module Keep Alive Memory (KAM) ErrorP0604 Internal Control Module Random Access Memory (RAM) ErrorP0605 Internal Control Module Read Only Memory (ROM) ErrorP0606 PCM Processor FaultP0608 Control Module VSS Output “A” MalfunctionP0609 Control Module VSS Output “B” MalfunctionP0620 Generator Control Circuit MalfunctionP0621 Generator Lamp “L” Control Circuit MalfunctionP0622 Generator Field “F” Control Circuit MalfunctionP0650 Malfunction Indicator Lamp (MIL) Control Circuit MalfunctionP0654 Engine RPM Output Circuit MalfunctionP0655 Engine Hot Lamp Output Control Circuit MalfucntionP0656 Fuel Level Output Circuit MalfunctionP0700 Transmission Control System MalfunctionP0701 Transmission Control System Range/PerformanceP0702 Transmission Control System ElectricalP0703 Torque Converter/Brake Switch B Circuit MalfunctionP0704 Clutch Switch Input Circuit MalfunctionP0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)P0706 Transmission Range Sensor Circuit Range/PerformanceP0707 Transmission Range Sensor Circuit Low InputP0708 Transmission Range Sensor Circuit High InputP0709 Transmission Range Sensor Circuit IntermittentP0710 Transmission Fluid Temperature Sensor Circuit MalfunctionP0711 Transmission Fluid Temperature Sensor Circuit Range/PerformanceP0712 Transmission Fluid Temperature Sensor Circuit Low InputP0713 Transmission Fluid Temperature Sensor Circuit High InputP0714 Transmission Fluid Temperature Sensor Circuit IntermittentP0715 Input/Turbine Speed Sensor Circuit MalfunctionP0716 Input/Turbine Speed Sensor Circuit Range/PerformanceP0717 Input/Turbine Speed Sensor Circuit No SignalP0718 Input/Turbine Speed Sensor Circuit IntermittentP0719 Torque Converter/Brake Switch B Circuit LowP0720 Output Speed Sensor Circuit MalfunctionP0721 Output Speed Sensor Range/PerformanceP0722 Output Speed Sensor No SignalP0723 Output Speed Sensor IntermittentP0724 Torque Converter/Brake Switch B Circuit HighP0725 Engine Speed input Circuit MalfunctionP0726 Engine Speed Input Circuit Range/PerformanceP0727 Engine Speed Input Circuit No SignalP0728 Engine Speed Input Circuit IntermittentP0730 Incorrect Gear RatioP0731 Gear 1 Incorrect ratioP0732 Gear 2 Incorrect ratioP0733 Gear 3 Incorrect ratioP0734 Gear 4 Incorrect ratioP0735 Gear 5 Incorrect ratioP0736 Reverse incorrect gear ratioP0740 Torque Converter Clutch Circuit MalfuctionP0741 Torque Converter Clutch Circuit Performance or Stuck OffP0742 Torque Converter Clutch Circuit Stuck OnP0743 Torque Converter Clutch Circuit ElectricalP0744 Torque Converter Clutch Circuit IntermittentP0745 Pressure Control Solenoid MalfunctionP0746 Pressure Control Solenoid Performance or Stuck OffP0747 Pressure Control Solenoid Stuck OnP0748 Pressure Control Solenoid ElectricalP0749 Pressure Control Solenoid IntermittentP0750 Shift Solenoid A MalfunctionP0751 Shift Solenoid A Performance or Stuck OffP0752 Shift Solenoid A Stuck OnP0753 Shift Solenoid A ElectricalP0754 Shift Solenoid A IntermittentP0755 Shift Solenoid B MalfunctionP0756 Shift Solenoid B Performance or Stuck OffP0757 Shift Solenoid B Stuck OnP0758 Shift Solenoid B ElectricalP0759 Shift Solenoid B IntermittentP0760 Shift Solenoid C MalfunctionP0761 Shift Solenoid C Performance or Stuck OffP0762 Shift Solenoid C Stuck OnP0763 Shift Solenoid C ElectricalP0764 Shift Solenoid C IntermittentP0765 Shift Solenoid D MalfunctionP0766 Shift Solenoid D Performance or Stuck OffP0767 Shift Solenoid D Stuck OnP0768 Shift Solenoid D ElectricalP0769 Shift Solenoid D IntermittentP0770 Shift Solenoid E MalfunctionP0771 Shift Solenoid E Performance or Stuck OffP0772 Shift Solenoid E Stuck OnP0773 Shift Solenoid E ElectricalP0774 Shift Solenoid E IntermittentP0775 Pressure Control Solenoid B MalfunctionP0776 Pressure Control Solenoid B PerformanceP0777 Pressure Control Solenoid B Stuck OnP0778 Pressure Control Solenoid B ElectricalP0779 Pressure Control Solenoid B IntermittentP0780 Shift MalfunctionP0781 1-2 Shift MalfunctionP0782 2-3 Shift MalfunctionP0783 3-4 Shift MalfunctionP0784 4-5 Shift MalfunctionP0785 Shift/Timing Solenoid MalfunctionP0786 Shift/Timing Solenoid Range/PerformanceP0787 Shift/Timing Solenoid LowP0788 Shift/Timing Solenoid HighP0789 Shift/Timing Solenoid IntermittentP0790 Normal/Performance Switch Circuit MalfunctionP0801 Reverse Inhibit Control Circuit MalfunctionP0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit MalfunctionP0804 1-4 Upshift (Skip Shift) Lamp Control Circuit MalfunctionP1086 Tumble generator valve #2 (LH) position sensor circuit low inputP1087 Tumble generator valve #2 (LH) position sensor circuit high inputP1088 Tumble generator valve #1 (RH) position sensor circuit low inputP1089 Tumble generator valve #1 (RH) position sensor circuit high inputP1090 Tumble generator valve #1 (RH) malfunction (stuck open)P1091 Tumble generator valve #1 (RH) malfunction (stuck close)P1092 Tumble generator valve #2 (LH) malfunction (stuck open)P1093 Tumble generator valve #2 (LH) malfunction (stuck close)P1094 Tumble generator valve circuit #1 (opencircuit)P1095 Tumble generator valve circuit #1 (overcurrent)P1096 Tumble generator valve circuit #2 (opencircuit)P1097 Tumble generator valve circuit #2 (overcurrent)P1110 Atmospheric pressure sensor low inputP1111 Atmospheric pressure sensor high inputP1112 Atmospheric pressure sensor range/performance problemP1130 Front oxygen sensor circuit malfunction (open circuit)P1131 Front oxygen sensor circuit malfunction (short circuit)P1134 Front oxygen (A/F) sensor microcomputer problemP1137 Front oxygen (A/F) sensor circuit range/performance problemP1139 Front oxygen (A/F) sensor #1 heater circuit perfomance/range problemP1141 Mass air flow sensor circuit range/perfomance problem (low input)P1142 Throttle position sensor circuit range/performance problem (low input)P1146 Pressure sensor circuit range/performance problem (high input)P1230 Fuel pump control unit malfunctionP1244 Wastegate control solenoid valve malfunction (low input)P1245 Wastegate control solenoid valve malfunction (fail-safe)P1301 Fire due to increased exhaust temperatureP1312 Exhaust temperature sensor malfunctionP1400 Fuel tank pressure control solenoid valve circuit low inputP1420 Fuel tank pressure control solenoid valve circuit high inputP1443 Evaporative emission control system vent control function problemP1480 Cooling fan relay 1 circuit high inputP1507 Idle control system malfunction (fail-safe)P1510 Idle air control solenoid valve signal 1 circuit low inputP1511 Idle air control solenoid valve signal 1 circuit high inputP1512 Idle air control solenoid valve signal 2 circuit low inputP1513 Idle air control solenoid valve signal 2 circuit high inputP1514 Idle air control solenoid valve signal 3 circuit low inputP1515 Idle air control solenoid valve signal 3 circuit high inputP1516 Idle air control solenoid valve signal 4 circuit low inputP1517 Idle air control solenoid valve signal 4 circuit high inputP1518 Starter switch circuit low inputP1540 Vehicle speed sensor malfunction 2P1544 High exhaust temperature detectedP1560 Back-up voltage circuit malfunctionP1590 Neutral position switch circuit high inputP1591 Neutral position switch circuit low inputP1592 Neutral position switch circuit (MT model)P1594 Automatic transmission diagnosis input signal circuit malfunctionP1595 Automatic transmission diagnosis input signal circuit low inputP1596 Automatic transmission diagnosis input signal circuit high inputP1698 Engine torque control cut signal circuit low inputP1699 Engine torque control cut signal circuit high inputP1700 Throttle position sensor circuit malfunction for automatic transmissionP1701 Cruise control set signal circuit malfunction for automatic transmissionP1703 Low clutch timing control solenoid valve circuit malfunctionP1711 Engine torque control signal 1 circuit malfunctionP1712 Engine torque control signal 2 circuit malfunction
Filed Under: Versa Articles Tagged With: nissan versa CEL SES dtc code extract
