Infiniti M35/M45 How-To Guides and FAQ
June 3, 2014 by Ilya
You’ll want to bookmark this page for future reference. Also, if you have suggestions for a useful writeup, please post up here:
Infiniti M35 / M45 Useful Discussions and Articles
Infiniti Factory Service Manuals
Infiniti Technical Service Bulletins
Click here for the newer M37/M56/Q70 guides, basic maintenance and FAQ.
General
HowTo: Post Your Images In Threads
Basic Specifications
Bulb Size Replacement Chart
Dealer Experiences
Enter Diagnostic Mode (For Cell Volume and Backup Cam)
iPod Integration Compatibility
OEM Parts Information (part numbers, prices, etc.)
Important Discussions
Discussion – Aftermarket/OEM Suspension Replacement – KYB or OEM
Discussion – Gas/MPG – What can we do
How To: Determine Wheel Fitment
How To: Determine Wheel + Tire Fitment (enter OEM numbers on left side – enter your changes on right)
How To: Reset ECU, Idle, Throttle, etc
Lug Nut Information/Discussion
Official Detailing Thread
Official Grille Thread
Official Lighting Thread
Official Suspension Thread | M35/M45 Lowering Springs Brand Comparison w/ Pictures
Official Wheel/Rims Thread
What Kind of Coolant Can I Use?
Elite Warranty Information Thread
Warranty Work/TSB Information Thread
Interior
How To: Audio Upgrade
How To: Change Interior to LED
How To: DIY LED Map Light
How To: Fix Auto-Up Window’s not working
How To: Fix Glove Box Rattle
How To: Fix Broken Seat Bracket | Link 2
How To: Re-Cover Dashboard
How To: Remove Glovebox
How To: Remove Interior Trim Pieces
How To: Remove Rear Deck
How To: Remove Rear Seat (06-10) | Link 2
How To: Replace Cracked Navigation Screen
How To: Replace In-Cabin Air Filter
How To: Replace Seat Filters
How To: Replace Trunk Struts
How To: Seat Heater CCS Module Replacement
Exterior
06-07 Foglight Replacement Part Numbers
How To: Adjust Headlights
How To: Change Bulbs to LED
How To: Clean Muffler Tips
How To: Clean/Polish Headlights
How To: Custom DRLs (Daytime Running Lights)
How To: Fix Sunroof Drain Tube Leak
How To: Install 5K or 6K White Amber Switchback V3 Triton LED System (Version 2)
How To: Install LED Mirror Covers
How To: Install LED Strips for Headlights
How To: Install Switchback LED’s in Front Turn Signals
How To: Paint Brakes
How To: Paint Headlights
How To: Replace/Change Grille
How To: Replace Headlight Bulbs
How To: Replace Headlights
How To: Replace License Plate Bulbs
How To: Replace Front Turn Signals
How To: Replace Rear Turn Signals
How To: Replace Reverse Lamps
How To: Tint Tail Lights w/ VHT Night Shade
How To: Upgrade 06/07 Front End to 08/09 Sport
How To: Upgrade Front End Lighting | Link 2 (uses pics from Link 1)
How To: Upgrade Rear Turn Signals to LED (Y50)
How To: Wire Up Independent Fogs (KP Technologies module needed – post 4)
Electrical
How To: 14 Speaker Sound Upgrade
How To: Battery Replacement (see post #4 on page 1)
How To: Change A/C and Navigation Control LED Color
How To: Install aftermarket navigation (Y34, Pre-06)
How To: Install Audiovox Unit
How To: Install Headrest Monitors
How To: Install Single DIN Radio in Glovebox
How To: iPod Integration (OEM-Like/DIY)
How To: Navigation Hack
How To: PA15-INFI Installation (iPod/3.5mm AUX) | Link 2
How To: PA15-NIS Review (for SAT capable but not equipped M’s)
How To: Radio Removal (06+)
How To: Radio Removal (06+) and Grom Audio Interface Installation
How To: Reset Your ECU
How To: Subwoofer Installation (Y34 M35/M45 – pre-2006 M)
How To: Subwoofer Installation (Y50 – 2006+ M) (3rd Post Down)
How To: Underbody Side Puddle Lights Installation
Engine
How To: Add Oil Catch/Separator Can
How To: Change Crankshaft/Camshaft Position Sensors – P0340 & P0335 (V8/M45)
How To: Change Engine Belts (M35 Link) | M45 Link 1 (post #9) | M45 Link 2
How To: Change Oil (06+ M35 – Y50)
How To: Change Oxygen Sensors (Sensor 2 Banks 1 & 2) – 06+ M35 – Y50
How To: Change PCV Valve (M35 – VQ35DE)
How To: Change Spark Plugs (M35 – VQ35DE)
How To: Clean MAF sensor
How To: DIY Cold Air Intake (M35 – VQ35DE)
How To: Fix Squeaky Tensioner Pulley | Some background info from How To creator
How To: Replace Electromagnetic Coil for AC Compresser Clutch
How To: Replace Valve Cover Gaskets (M45 – VK45DE)
How To: Seafoam Your Engine (Basic Info) | Detailed How To [edit: missing pictures now]
Exhaust
Official Exhaust Thread
Suspension and Steering
Discussion: Coilovers vs Lowering Springs Thread
How To: Change Your Stabilizer Link(s)
How To: Install Lowering Springs (2006-2010)
How To: Install BC Coilovers
How To: Install D2 Coilovers
How To: Replace Front Bearings/Hubs
Brakes
Akebono G37 Sport Big Brake Kit Review and Tips
G37 BBK Parts List
G37 BBK Wheel Spacer Information
How To: Change M35/M45 Brakes (Front and Rear)
How To: Diagnose, Repair, and Bleed Master Cylinder & Brakes
Transmission and Drivetrain
How To: Change Tranmission Fluid and Install Oil Cooler | Link 2
How To: Convert Rear Diff to G37 Diff (M45)
How To: Front Driveshaft Replacement (Y50 M35x)
How To: Front and Rear Differential Fluid Swap (Y50 M35x)
How To: Transfer Case Replacement (Y50 M35x)
Filed Under: Uncategorized Tagged With: DIY, FAQ, how to, infiniti m35, infiniti m45, InfinitiMHowTo, nissan fuga
infiniti M56 DIY
Infiniti M37/M56/Q70 How-To Guides and FAQ
Infiniti M35 M37 M45 M56 Cabin Filter Replacement
Do It Yourself Infiniti VQ35HR Air Filter Change
Do It Yourself Bumper Removal – Nissan Altima
240sx2nr95’s Kouki S14 Sideskirts Installation
How to: Modifying a S13 240SX steering rack for manual steering
Removing OEM Radio and Installing GROM USB/iPod Adapter
LED Upgrade Project and Dome Light Conversion
Dome Light Replacement Procedure for Infiniti M-series
How To Install HIDs for the Low Beams and Foglights on M35 / M45
