Install a PCV Catch-Can to Your Versa
January 3, 2010 by Greg
SO I decided to install an in-line catch can post PCV valve. I purchased all my materials at my local ace hardware store. Using a compressor’s water/air separator, and some 3/8ths inch fuel line, some fittings and ring clamps, I now have an inexpensive system to remove oil and other contaminates from re-entering the intake manifold and thereby helping to keep the upper engine assembly much cleaner for much longer. This should reduce the amount of buildup occurring on the throttle body, intake plenum, valves and from entering the combustion chamber.
Here is the water/air separator. I got it from ACE for like 25 bucks and removed the small filter that was in it. It has a bleed valve on the bottom so you can drain it, but its faster to just screw the bottom off and dump it out.
[img]https://forum-attachments.sfo2.digitaloceanspaces.com/pb/jackkeni/vv157/i679.
Filed Under: Versa Articles Tagged With: nissan versa pcv catch can install
