What feels like a CVT about to fail may not be a transmission issue at all. Here’s how one owner traced it to the real culprit.
Background
Vehicle: 2016 Infiniti QX60
Mileage: 125,000
CVT/Front/Rear Diff fluid changed at 75K and 105K miles
Issue: Jerking at 1,900–3,000 RPM, often confused for CVT “judder”
Initial Symptoms
- Intermittent jerking during acceleration (in all gears, even in manual mode)
- CEL triggered with
P0302 (Cylinder 2 Misfire), later aP0300 - No codes related to CVT judder (
P17F0orP17F1)
Ruling Out a Failing CVT
A failing CVT usually exhibits symptoms like:
- “Judder” under light throttle, especially uphill
- Visible RPM fluctuations not tied to throttle input
- Stored
P17Fxcodes in the TCM
None of these symptoms were present. A scan using the CVTz50 app showed:
- Healthy transmission pressures
- Normal operating temperatures (thanks to the 140F external cooler)
- No stored CVT codes
Steps Taken
- Replaced Cylinder 2 coil pack — reduced misfire, but not resolved
- Replaced spark plug — improved performance slightly
- Reviewed fuel trims (STFT/LTFT) — no signs of injector failure or vacuum leak
- Suspected carbon buildup — ran Seafoam and BG44K through intake and fuel tank
- Cleaned MAF sensor using CRC MAF Cleaner
- Performed IAVL procedure using CVTz50 to reset idle air values
Resolution
After cleaning the MAF and performing the IAVL, the car ran smoothly for over 1,000 miles, including a round trip from Charlotte to Columbus.
The culprit? A dirty MAF sensor and piston crown carbon buildup — not the CVT!
Takeaways for Other Nissan / Infiniti CVT Owners
- Don’t jump to CVT failure. Misfires and ignition issues can mimic transmission problems.
- MAF cleanliness matters. Dirty readings can throw off fuel trims and cause misfires.
- Carbon buildup can cause misfires. Seafoam or ATF induction can help clean the combustion chambers. NOTE: This *must* be done properly!
- Use OEM ignition parts. Aftermarket coil packs often don’t hold up.
- Apps like CVTz50 provide powerful diagnostic tools for Nissan/Infiniti CVTs.
