S13 Hazard Switch Bulb Replacement
February 23, 2014 by Greg
37
You have two choices. You can buy another bulb and holder from the dealer, or order one online. It’s your choice, but the dealer route is more expensive but less time consuming.
Here’s the bulb you need (should be available on Amazon).
12
13
Properly cut down.
14
Carefully pry the two parts of the switch apart.
38
39
40
41
42
Remove the rubber bulb holder.
43
Unwrap the wires from the bulb holder and remove the bulb. Be careful with the holder, as you’ll need to reuse it.
43
Carefully remove the bulb condom. You’ll need to reuse it, so make sure to get it off without ripping it.
44
Match up the new bulb to the old one, and cut the wires to length.
27
As you can see, the replacement is a bit bigger, but it still fits fine. Pay no attention to the switch in the background. The steps are similar to most switches inside the S13.
Now reverse the disassembly order and you’ll be back on your way.
Written by Nico member qat727.
Filed Under: 240sx Articles
