Install an Aftermarket GPS and Backup Camera
December 31, 2009 by Greg
Applied Vehicle(s): Infiniti G35, Infiniti G37 Difficulty Rating:
Estimated Labor Time: 1½ hours Written By: G35MoonRiver
Estimated Total Cost: $220.00
Find related tutorials and information on your vehicle in NICOclub’s Nissan Forums & Infiniti Forums
The rear view on my 2007 Infiniti G35 Coupe is extremely limited that every time I backup it makes me extremely nervous, so I decided to install a backup camera, as well as an aftermarket GPS. I’m sure that this entire process will be helpful to those who need it, particularly the process of uninstalling the shifter panel.
I am very happy pleased with the result.
Got a GPS with an Audio/Visual input from eBay
As well as a wireless rear view camera, it comes with a camera, a transmitter and a receiver.  Some models come with an integrated camera in a license plate frame.
GPS stuck on the cubby lid with 3M Velcro tape.
When the cubby lid is closed, the screen is removed from the line of sight, therefore deterring any potential theft.
Here’s how I did it:
1) Lift the shifter panel – the hardest part.
First, inserted some pieces of hard transparent plastic such as on toy packing box, around and underneath the panel, note: inserted two pieces in one spot then wedge some small pieces of thick hard paper (again it can be from the packing box) in between plastic, do this along the panel, insert more paper until the panel lifts.
With the panel separated from the black plastic panel, lift the the panel by the ashtray lid and pull downwards to the shifter, it’s a big tricky lifting the rear end of the panel helps. See picture above. Now you got it!
2) Take off the armrest
Then the big panel
I then unscrewed the screw on the soft narrow long panel on the side the screw is under the shifter panel.
From there I lifted the front end of the big panel
Now the rear end of soft long narrow piece can be lifted, as well as middle of it, carefully lift it up, at the same time pull it down, to take it off.
After that, I ran a USB cable from the cigarette lighter socket to out side the cubby
Then I drilled a hole on the side of the cubby to insert the cable in the cubby
There is a hole in the back of the trunk through it the license plate lights wires go out. It’s perfect for the camera cable.
You must fish the cable inside the hole.
From there I poked a hole large enough on the rubber plug to let the cable go through.
Then I soldered the transmitter hot wire on the backup lights positive wire, it’s pink, and ground the transmitter negative wire, I bolted on the amplifier mount.
placed the receiver in the cubby
Almost done! I then mounted the camera onto two brackets
And finally I mounted it on the license plate. It relatively unnoticeable, unless you bend down and look for it.
Connected everything together, as soon as shifted into R, it showed the rear view, regardless what the GPS mode is!
I installed the Igo Prime on the GPS, now I have a GPS and rear view display in a single unit, it’s great!
Filed Under: G35-G37 Articles Tagged With: aftermarket, backup camera, camera, gps, infiniti g35, infiniti g37, install, rear, screen
