Alcohol and Water Injection – The Basics
Alcohol Injection Want to run 5-10 PSI more boost then you are now? Sure you do, unless of course you’re opposed to adding 50-100 hp to your car. With alcohol injection you can do just that, all while buying your gas from the pump. I’ve been a huge fan of alcohol injection for many years […]
Filed Under: General Automotive, Tuning Tagged With: alcohol injection, infiniti, injection kits, injectors, Nissan, performance, water injection
