240sx Water Pump Replacement
December 10, 2009 by Aaron
by c-kwik Tools: – metric sockets and ratchet and open-end wrenches– drain pan Materials: – coolant Procedure: Begin by draining your coolant. Next remove your intake pipe and move the emissions lines out of the way. Take off the fan shroud so you can pull off the fan and clutch assembly together. Free the water […]
Filed Under: 240sx Articles Tagged With: 240sx, coolant, gasket, power steering pump, sealant, water pump replacement, waterpump
