5th-Generation Maxima: Car Audio Wiring Codes
December 10, 2009 by admin
  • Do it yourself Maxima Audio Wiring Codes - 5th-Gen1299
  • Do it yourself Maxima Audio Wiring Codes - 4th-Gen1300
The following information was researched via multiple Maxima FSM’s.
Base Headunit plug diagram
Bose Headunit plug diagram
Bose amp plug diagram
Speaker Wiring Chart (Both Bose and Non-Bose)
Information provided by:audtatious
Filed Under: I30-I35 Articles, Maxima Articles Tagged With: audio, bose, maxima, wiring
Technical Articles: 4th-Gen Maxima:Car Audio Wiring Codes
5th-Generation Maxima Front Speaker Removal
Nissan Maxima – Heated Side Mirror Installation
4th-Generation Maxima: How to Install a 2000 VI Manifold
Maxima Rear Sway Bar Install
4th-Gen Maxima Knock Sensor Testing
4th-Gen Maxima: Replacing Motor Mounts
5th/6th-Gen Maxima – How to Reset ECU
Installing a PCV Blow-by Oil Catch on a Nissan Maxima/Infiniti I30
Maxima and I35 Airbag light reset procedure
