Sentra SE-R, NX2000, G20 Tune-up and Maintenance Bible
December 10, 2009 by admin
Nissan 2.0 Engine Maintenance Bible By:RED_DET Well folks here is your guide to making your pride and joy run at optimal performance. Starting with common problems and solutions: PROBLEM: Erratic Idle and jumping idle, some other symptoms are also: sluggish performance, real bad mileage, injector leak malfunction code, o2 sensor voltage stuck at 800 mv […]
Filed Under: Sentra Articles Tagged With: 2.0, air filter, egr, engine maintenance, g20, mileage, Nissan, nx2000, radiator, rpm, sentra, sr20de, tps, tune up
