Sentra SE-R, NX2000, G20 Tune-up and Maintenance Bible
Nissan 2.0 Engine Maintenance Bible By:RED_DET Well folks here is your guide to making your pride and joy run at optimal performance. Starting with common problems and solutions: PROBLEM: Erratic Idle and jumping idle, some other symptoms are also: sluggish performance, real bad mileage, injector leak malfunction code, o2 sensor voltage stuck at 800 mv […]
Filed Under: Sentra Articles Tagged With: 2.0, air filter, egr, engine maintenance, g20, mileage, Nissan, nx2000, radiator, rpm, sentra, sr20de, tps, tune up
G35 Spark plug replacement
OEM part # is 22401-5m015 TOOLS: 6 NGK LFR6AIX-11 Iridium IX Sparkplugs (these are 1 heat range cooler than stock)3/8″ Rachet3/8″ long extension (at least ten inches)10mm socket16mm “deep” socket (or “sparkplug socket”)Magnetic pick up tool3-prong grabber (optional, you’ll need it if you don’t have a “sparkplug socket”)PliersTorque Wrench Most people would have these tools […]
Filed Under: G35-G37 Articles Tagged With: G35, how to, iridium, ngk, spark plug, sparkplugs, tune up, vq35de
