Automotive Terms and Abbreviations
December 10, 2009 by admin
AA/F or AFR – Air / Fuel RatioAAA American Automobile AssociationAAC – Aux. Air Cut Valve (See IAC)ABS: Anti-lock Brake SystemACL- Air cleanerAFM- Air Flow Meter (See MAF)AFPR: Adjustable Fuel Pressure RegulatorAPP – Accelerator Pedal Position (sensor)ASCD – Automatic Speed Control DeviceAT or A/T – Automatic TransmissionATDC : After top dead centerATF – Automatic Transmission […]
Filed Under: General Automotive, Infiniti Articles, Nissan articles Tagged With: adjustable fuel pressure, adjustable fuel pressure regulator, air flow meter, air fuel ratio, air resources board, american automobile association, automatic transmission fluid, barometric pressure sensor, brake master cylinder, california air resources, california air resources board, clutch master cylinder, controller area network, crank angle sensor, crankshaft position sensor, daytime running lights, dlc data, dual overhead cams, fuel pressure regulator, variable valve timing
Navigating Nissan Rogue CVT Transmission Problems & Recalls
Helpful Hacks and Tricks for Finding and Buying a new Ford Maverick
