Automotive Terms and Abbreviations
AA/F or AFR – Air / Fuel RatioAAA American Automobile AssociationAAC – Aux. Air Cut Valve (See IAC)ABS: Anti-lock Brake SystemACL- Air cleanerAFM- Air Flow Meter (See MAF)AFPR: Adjustable Fuel Pressure RegulatorAPP – Accelerator Pedal Position (sensor)ASCD – Automatic Speed Control DeviceAT or A/T – Automatic TransmissionATDC : After top dead centerATF – Automatic Transmission […]
Filed Under: General Automotive, Infiniti Articles, Nissan articles Tagged With: adjustable fuel pressure, adjustable fuel pressure regulator, air flow meter, air fuel ratio, air resources board, american automobile association, automatic transmission fluid, barometric pressure sensor, brake master cylinder, california air resources, california air resources board, clutch master cylinder, controller area network, crank angle sensor, crankshaft position sensor, daytime running lights, dlc data, dual overhead cams, fuel pressure regulator, variable valve timing
1991 Nissan 240sx NICO Forums Ride of the Month for April 2008
       James Sisson (PapaSmurf2k3) 1991 Nissan 240sx I originally purchased my 91 240sx back in 2002. I was 17 and my first car was a 1987 Nissan Maxima that I picked up in non running condition for $100. I learned a good deal about car mechanics on that car, and it was pretty nice (power […]
Filed Under: 240sx Articles, Featured Ride Tagged With: 180sx VLSD, 1991 240sx, 1991 nissan, 1991 Nissan 240sx, 2 10" kicker subwoofers, 225/45 Toyo Proxes, 240sx automatic brake booster, 3" exhaust, 300zx Brake master cylinder, 300zx front brake conversion, adjustable fuel pressure regulator, APS HFTO turbine outlet adaptor, Blaupunkt speakers, Blow Through Z32 MAF, Centerforce Dual Friction clutch, clutch box removed, EGR delete, eibach pro kit springs, Greddy Profec E-01 boost controller, hardened NISMO wheel studs, JGS DIY manifold, Kenwood 600W 2 channel amp, Kenwood head unit, Konig Monsoon 18" wheels, KYB AGX struts, Magnaflow resonator, nissan 240sx, NISTUNE ECU 550cc injectors, SPL tension rods, Supertech 9:1 pistons, TD06 23G turbo, Walbro fuel pump
