350Z and G35 ECU reset procedure
December 10, 2009 by admin
How to reset your ECU and perform the Throttle Pedal Release and Idle Air Volume Learning procedures on an Infiniti G35 and the Nissan 350Z. Before attempting any of the following procedures, it is advisable that you read through the instructions thoroughly and familiarize yourself with them. A stop watch or an analog clock with […]
Filed Under: 350z Articles, G35-G37 Articles Tagged With: accelerator pedal, cel, check engine light, ecu, infiniti g35, Nissan, nissan 350z
Technical Articles: G35- How to:Reset ECU, Throttle Pedal Release & Idle Air Volume Learning
Filed Under: G35-G37 Articles Tagged With: accelerator pedal, air volume, cel, check engine light, ecu, infiniti g35, nissan 350z, throttle valve
