350Z Raceland Coilover Install
September 10, 2013 by ChrisL
With a fairly tight budget, and other projects on hand, Raceland’s affordable coilovers were the perfect candidate to drop the stance of my 350Z daily driver without taking breaking the bank.
Filed Under: 350z Articles, Product Review Tagged With: 350Z coilover install, install coilovers on 350Z, Nissan, nissan 350z, Raceland, Ride height, Z33 coilover install
Car and Driver Nissan 350Z for Sale
December 31, 2009 by Greg
Car and Driver Nissan 350Z for Sale Grand-Am Continental Tire Challenge Car We built this car as part of a Car and Driver Magazine article and it was featured in the August 2008 issue. No expense was spared in its preparation. From the seam welding and detail on the roll cage, to the Bosch MS […]
Filed Under: 350z Articles, Nissan Motorsports Articles Tagged With: car and driver magazine, challenge car, nissan 350z
350Z and G35 ECU reset procedure
How to reset your ECU and perform the Throttle Pedal Release and Idle Air Volume Learning procedures on an Infiniti G35 and the Nissan 350Z. Before attempting any of the following procedures, it is advisable that you read through the instructions thoroughly and familiarize yourself with them. A stop watch or an analog clock with […]
Filed Under: 350z Articles, G35-G37 Articles Tagged With: accelerator pedal, cel, check engine light, ecu, infiniti g35, Nissan, nissan 350z
Technical Articles: G35- How to:Reset ECU, Throttle Pedal Release & Idle Air Volume Learning
Filed Under: G35-G37 Articles Tagged With: accelerator pedal, air volume, cel, check engine light, ecu, infiniti g35, nissan 350z, throttle valve
2004 Nissan 350Z – NICOclub Ride of the Month September 2005
ATI ProCharger w/ 9psi pully Shielded CAS wire Custom Grounding Kit AAM Y Pipe High flow Cats J&S Ultra Safeguard AAM ECU reflash B&M Short Shift Kit GReddy AirFlow Plate EGT Gauge in Drivers door AC vent Plenum Spacer Greddy Oil Catch Can Koni 8241 adjustable shocks Greddy Blowoff Valve 2004 Nissan 350Z – Owned […]
Filed Under: 350z Articles, Featured Ride Tagged With: adjustable shocks, braided brake lines, brake pads, daytona blue, fuel system, grounding kit, manual transmission, nissan 350z, project mu brake pads, short shift kit, steel braided brake lines
How to replace your Nissan 350Z shift knob with an aftermarket knob
Nissan 350z Varies 5 minutes NICOclub Rating System dasoupdude Tools Needed: -Replacement Shift knob (of your choice) -Flat-head Screwdriver. -Protective Tape -Vice Grips Pry open the shift console with a flathead, I marked the sweet spots where the clips are near in blue tape. Once the clips have been detached, go ahead and pull towards […]
Filed Under: 350z Articles Tagged With: nismo, nissan 350z, replacement, shift knob, shiftknob
