Installing Cruise Control for SR20DET Swapped 240sx
December 10, 2009 by Aaron
The car is a 1990 s13 with a redtop SR. Parts:KA throttle bodyShort piece of electrical wire (about 1.5 feet) Procedure:First things first, swap over the throttle body from your old KA onto the SR. Next, there are two different ways you could go. What seems like the easiest is to use the KA throttle […]
Filed Under: 240sx Articles Tagged With: cruise control module, ecu, redtop, s13, throttle body, throttle cable, throttle plate
