Resolving Rough IdleBy Jesda Gulati Fuel Injectors – Bad gas or regional mixtures tend to result inearly injector failures. A fuel smell in the cabin also hintsat injector problems. Non-OEM injectors are not recommended.Learn how to test your injectors Fuel System- Purchase a can of BG44kfrom Infiniti of Scottsdale and add it to a 3/4 […]
Altima 3.5 Injen Short Ram Intake Install
Okay, first off, I’d like to say that the installation is quite simple and straight forward. If you have basic mechanical skills, it shouldn’t take more than 40-45 minutes tops. I have a lot of experience with installing intakes, exhausts, headers, etc., and it only took me 35 minutes, but that’s because I took pics […]
Maxima throttle body cleaning
Ok, so most of us are driving around 10 year old machines with a bunch of miles. Some of us like going very fast, some like gas mileage. Some like both. Here is a writeup on how to do a real (not dealer cop out) cleaning of your throttle body. This is done on a […]
Installing Cruise Control for SR20DET Swapped 240sx
The car is a 1990 s13 with a redtop SR. Parts:KA throttle bodyShort piece of electrical wire (about 1.5 feet) Procedure:First things first, swap over the throttle body from your old KA onto the SR. Next, there are two different ways you could go. What seems like the easiest is to use the KA throttle […]
