Clearing Codes on the G35 and 350Z There are several ways to clear ECU error codes. – Scan Tool If using a scan tool, follow tool manufacturer’s instructions to clear Codes. – Manual Method Here is a quick way to reset your ECU. It is also known to clear codes thrown, and turn off the […]
1989-1994 Nissan Common OBD-I codes
-Access the ECU and position it for observing the diodes. -If the engine does not run, turn the key on and proceed to step #4. -Start the engine and warm it to operating temperature then idle. -Turn the diagnostic mode selector on the ECU fully clockwise until both diodes flash 3 times then turn the […]
