Nissan Fog Light Modification Without Headlights
Fog Light Modification By:NISTECH NOTE:This is for a Pathfinder / QX4, but MAY be adaptable to other Nissan models as well. The fog lamp relay is powered through the headlamp relay, so your headlights would need to be on to power the fog lamp relay. The ground side of the relay goes through the foglamp […]
Filed Under: Pathfinder Articles Tagged With: fog lamp, fog light, headlight switch, headlights, high beams, how to, low beam, Nissan
