Applied Vehicle(s): Infiniti I30, 4th Gen. Maxima Difficulty Rating: Estimated Labor Time: 3 hours Written By: loystock Estimated Total Cost: $290.00 Find related tutorials and information on your vehicle in NICOclub’s Maxima Forum & I30 / I35 Forum Specification (and Pricing from IoS – infinitipartsUSA.com): -Front Rotor: 26mm new/24mm minimum; Maximum Runout=0.07mm ($82.11 from IoS) […]
Checking Nissan Knock Sensor Resistance
I had a car in this morning with a P0325 (knock sensor), this example is a 97 Infiniti I30 since they are the easiest to show. 1:After confirming the code is present, get your multimeter and zero it out if you have the capability. 2:Disconnect the sensor 3:Connect your leads and view your results In […]
