1. Remove door panel. a) Remove screw at door open pull. b) Remove door handle trim, pry silver plastic trim piece from lower side with a screwdriver. There’s a small notch for the screwdriver blade to fit in. remove the two screws behind this cover. c) Lift window switch plate up from the front edge […]
