1. Slide arm rest out (this may be stuck, and require some pressure). 2. EASILY remove window switch plastic cover (It pops off, and breaks VERY easily). 3. Remove 3 screws holding door panel to frame. 4. Pop all plastic clips holding perimeter of door panel (be easy – take your time). 4a. Disconnect all […]
G35 Window fix
1. Remove door panel. a) Remove screw at door open pull. b) Remove door handle trim, pry silver plastic trim piece from lower side with a screwdriver. There’s a small notch for the screwdriver blade to fit in. remove the two screws behind this cover. c) Lift window switch plate up from the front edge […]
