Infiniti Q45 Rear Sway Bar Installation and Upgrade Steps Typically, your rear sway bar bushings will be hard and worn and deformed from years of use, so while you’re installing your new 20mm Active rear sway bar, I recommend new polyurethane bushings. Old and new side by side. Notice how much longer the OEM link […]
