300ZX Brake Upgrade for FRS/BRZ – Part 2
July 23, 2008 by Greg
    300zx Brake Upgrade for FRS/BRZ – Part 2 – How will they work? Assuming you’ve already read Part 1 of the 300ZX Brake Upgrade for FRS/BRZ, let’s cover the rest of this system. In this article I will talk about how this braking system performs in comparison to stock.  I will try to explain some […]
    Filed Under: 300zx Articles Tagged With: 300ZX, 4 piston calipers, Big Brake Kit, brake bias, brake pads, brakes, brz, calipers, cheap, cooling, frs, how it works, lines, rotors
    January 16, 2008 by Greg
      Would you like better brakes for your BRZ/FRS without spending $2k or more? In this article i will show you many options for brake upgrades ranging from professional aftermarket kits to a simple OEM upgrade.
      Filed Under: 300zx Articles Tagged With: 4 piston calipers, Big Brake Kit, brake pads, brakes, cheap, enjuku, heat capacity, KNS Brakes, Legacy GT, nicoclub, rotors, Scion FRS, stainless lines, Subaru BRZ, TunerZStore, upgrade, Z32 Brakes
