300ZX Brake Upgrade for FRS/BRZ – Part 2
July 23, 2008 by Eikon
    300zx Brake Upgrade for FRS/BRZ – Part 2 – How will they work? Assuming you’ve already read Part 1 of the 300ZX Brake Upgrade for FRS/BRZ, let’s cover the rest of this system. In this article I will talk about how this braking system performs in comparison to stock.  I will try to explain some […]
    Filed Under: 300zx Articles Tagged With: 300ZX, 4 piston calipers, Big Brake Kit, brake bias, brake pads, brakes, brz, calipers, cheap, cooling, frs, how it works, lines, rotors
    January 16, 2008 by Eikon
      Would you like better brakes for your BRZ/FRS without spending $2k or more? In this article i will show you many options for brake upgrades ranging from professional aftermarket kits to a simple OEM upgrade.
      Filed Under: 300zx Articles Tagged With: 4 piston calipers, Big Brake Kit, brake pads, brakes, cheap, enjuku, heat capacity, KNS Brakes, Legacy GT, nicoclub, rotors, Scion FRS, stainless lines, Subaru BRZ, TunerZStore, upgrade, Z32 Brakes
      Helpful Hacks and Tricks for Finding and Buying a new Ford Maverick
      Infiniti is preparing to change… again.
      NICOFest Carlisle 2022 Results
      NICOFest Carlisle 2022 Registration
      Suspension Upgrade Basics for Street or Track
      Yume Cars – Beware!
      Driver-to-driver communication – A relic from a bygone era?
      NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc. They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti. Information Copyright © 2000-2022 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
      Copyright © 2022 · NICO Club 2014 on Genesis Framework · WordPress · Log in
