Click Here for a How-To on removing your taillights– Clean the taillight you will be working on before proceeding – Using a bottle of a soapy water solution, spray the taillight down. Do the same for the vinyl overlay once you have peeled it from the backing. This ensures a slippery surface so you have […]
NICOclub Exclusive Road Test of the 2008 Altima Coupe
NICOclub.com Drives and Evaluates the 2008 Altima Coupe While our Associate Test Drive Editor was in Smyrna, Tennessee at the new Nissan plant, he was given the EXCLUSIVE opportunity to drive the unreleased Altima Coupe (scheduled for introduction in 2008). Of course, we couldn’t wait to get his review to you, as we’re eagerly awaiting […]
Altima Center Console Removal
DIY – Altima Center Console Removal Overview: This is a DIY for the removal of the center console to be able to install LEDs in the cup holders, replacement of heated seats switches, or work on the E-Brake system or whatever else is in the center console. Difficulty:2 Time:15 minutes Cost: depends on what you […]
Altima Coupe Painting Taillights
In this article we will be painting a set a Altima Coupe taillights. This is an alternative to using vinyl overlays as it is easier to apply and slightly more permanent. Note: Check with your local jurisdiction before performing this as it may not be legal in all states. Skill Level 1 of 5 Time […]
Altima Coupe Remove and Paint your AC vents
First off, materials you will need: Spray can of the paint you will useGrey Primer Filler100 grit sandpaperMasking tapeFlathead screwdriver (stubby)Phillips head screwdriverCardboard First off is the defog vent. Use a stubby screwdriver, it will come in very handy for removing these vents. You stick the Flathead screwdriver in between the dash and the vent […]
Removing Altima Coupe Door Panels
Ok, how to remove door panels. Here we go: First, pry off the cover inside the door handle. Then unscrew the screw inside. Now, pry up the cover starting from the bottom. Once unclipped, undo the wire connection. Then place the assembly aside. Now pry off the trim peace, starting from the rear, and moving […]
Altima Coupe Removing Seats and Carpet for Sound Dampening Install
So I finally found the time to tear apart the A/C and apply the B-Quiet material to the car. I honestly cannot believe how huge a difference this made. There’s a patch of bricks down the street from my house I drive over every day, and after the install I didn’t hear the bricks under […]
Altima Coupe How to Install Sequential Turn Signals
How to Install Sequential Turn Signals This article shows you how to install Oznium Orange flexible LED strips to be used as sequential turn signals on your Nissan Altima. Ok Guys and Girls, I had to do it! Especially since I told LBC about it. The whole process takes about 4 hours to do. Probably […]
Removing Altima Coupe Chrome Grill Inserts for Painting
For those of you who plan on painting the chrome grill inserts, here is a quick how-to. I just got the plastic pieces off today. I took a few pictures for those who havent done it yet but are planning on it. The key to all of this is patience. Removing the Inserts Take a […]
Altima Instrument Gauge Lighting Change
First, I separated the the three pieces. They are easy to disassemble. Nothing but clips holding it together. Next, I separated the Bezel that has the notches for the speed, rpm, ect. I didn’t take off the needles because, I have had a bad experiences with that before. So, I peeled back the gauges and […]
