240sx S13 Dimmer Switch Bulb Replacement
February 23, 2014 by Greg
240sx Dimmer Switch Bulb Replacement You have two choices. You can buy another bulb and holder from the dealer, or order it online. It’s your choice, but the dealer route is more expensive but less time consuming. Here’s the bulb you need. Properly cut down. Dimmer Switch Remove the bulb with a screwdriver and a set of […]
Filed Under: 240sx Articles Tagged With: 240sx, automotive lighting, dash lights, DIY, Nissan articles, s13
Lighting choices for your car – HID, Halogen, kits
As you know, whether from seeing cars on the road or hearing people talk, there are multiple forms of automotive lighting available. I will discuss standard halogen lighting and HID lighting as well as important terms in the following tech article.  Many automotive manufacturers, including Nissan, Infiniti, Audi, VW, BMW, Toyota, Lexus, Acura, Ford, and […]
Filed Under: General Automotive Tagged With: automotive lighting, beam pattern, glass bulb, halogen bulbs, halogen headlight bulbs, halogen lighting, HID, incandescent light bulbs, light dispersion, light intensity
