Items Needed: -Ratchet with 10mm, 12mm, & 14mm sockets and an extension (I used a 3″)-2-3 ft cheater bar (You will NEED this unless you have a long handle ratchet)-Latex Gloves (optional)-2 Drive Belts (power steering/Alternator and A/C) Access First off, remove the intake scoop. Now remove the under body covering. This is the most […]
