VQ35DE 6MT G35 Accessory Belt Change
December 10, 2009 by admin
Items Needed: -Ratchet with 10mm, 12mm, & 14mm sockets and an extension (I used a 3″)-2-3 ft cheater bar (You will NEED this unless you have a long handle ratchet)-Latex Gloves (optional)-2 Drive Belts (power steering/Alternator and A/C) Access First off, remove the intake scoop. Now remove the under body covering. This is the most […]
Filed Under: G35-G37 Articles Tagged With: belt tension, belts, drive belts, G35, how to, idler pulley, idler pulleys, infiniti, power steering
Exhaust Extractor DIY – Tune Indoors!
Route 66 JDM Classic 2023 is in the books!
