How to remove Q45 HVAC Evaporator and Cooling Unit
Here’s a little write-up on how to remove the Cooling Unit from your G50 Q45. The Cooling Unit is where the AC evaporator is found as well as the expansion valve. I’m starting with the glove box already removed, since most of us have done this and to help keep this short and sweet. I’ve […]
Filed Under: Q45 Articles Tagged With: ac evaporator, air conditioning, blower motor, expansion valve, freon, g50, heater, how to, HVAC, q45
Maintaining Your Infiniti Air Conditioner
Maintaining Your A/C System by:db-autotek Over time, your once-cold A/C system might start to deteriorate until you suddenly realize it’s no longer blowing cold. Regular maintenance is critical, including cleaning the evaporator fins, changing the charge every 2 years, and ensuring system is clean and debris-free. Mine had ceased blowing cold air, and it turns […]
Filed Under: Car Care & Detailing, General Automotive Tagged With: air conditioner, blower motor, cold air, how to, HVAC, infiniti
