DIY Knock Detection
May 30, 2011 by Greg
I was scouring the web in search of some affordable knock detection sensor, most products costing more then I cared to spend usually in the $200 to $600 range. I couldn’t believe how limited most of the products were for the amount of money they were charging. Essentially everything was a box that had some […]
Filed Under: Tuning Tagged With: Detonation, detonation control, knock control, knock sensor
4th-Gen Maxima Knock Sensor Testing
Testing the Knock Sensor (KS): – The KS MUST be checked with a digital ohmmeter. Analog ohmmeters may cause damage to vehicle. 1) Raise the hood. View the engine from the driver’s fender. Look into the deep valley between the cylinder banks and below the intake manifold. Identify the KS as a black item fastened […]
Filed Under: I30-I35 Articles, Maxima Articles Tagged With: 4th-generation, ecu, gas mileage, intake manifold, knock sensor, maxima, Nissan
