350Z and G35 manual transmission fluid change
Changing trans oil on a G35 6MT: NOTE:Do NOT use GL5 transmission fluid. It will damage the synchros in the Nissan transmission. You need GL4 fluid. Most fluid you buy at autoparts stores is GL5. I recommend a mixture of 2 quarts Redline MTL (70W-80) and 2 quarts Redline MT-90 (75W-90), as Nissan calls for […]
Filed Under: 350z Articles, G35-G37 Articles Tagged With: 350z, G35, how to, manual transmission, manual transmission fluid, mt 90, Nissan, nissan transmission, transmission fluid change
Altima Coupe Redline Manual Trans fluid tutorial
First of all, this is for everyone that experiences clunky shifting, hard to go in a lower gear, abrupt gear matching, or that just wants smoother shifting. What you have to do if you want to really get rid of those problems is change the MANUAL TRANSMISSION FLUID to a synthetic one. Wait until you […]
Filed Under: Altima Articles Tagged With: altima, manual, manual transmission fluid, mt 90, Nissan, redline, synthetic, transmission
