350Z and G35 manual transmission fluid change
Changing trans oil on a G35 6MT: NOTE:Do NOT use GL5 transmission fluid. It will damage the synchros in the Nissan transmission. You need GL4 fluid. Most fluid you buy at autoparts stores is GL5. I recommend a mixture of 2 quarts Redline MTL (70W-80) and 2 quarts Redline MT-90 (75W-90), as Nissan calls for […]
Filed Under: 350z Articles, G35-G37 Articles Tagged With: 350z, G35, how to, manual transmission, manual transmission fluid, mt 90, Nissan, nissan transmission, transmission fluid change
Nissan Transmission Control Unit Codes
NISSAN TCU CODES 1st -Vehicle speed sensor(A/T Revolution) circut2nd -Vehicle speed sensor/MTR (at Speedometer)3rd -Throttle position sensor or switch4th -Shift solenoid valve “A”5th -Shift solenoid valve “B”6th -Overrun clutch solenoid Valve7th -Torque converter solenoid valve8th -Fluid temp sensor/ ATCU power source circut9th -Engine speed signal circuit10th -Turbine revolution sensor11th -line pressure solenoid sensor
Filed Under: Infiniti Articles, Nissan articles Tagged With: Nissan, nissan transmission, solenoid, speed signal, speedometer, tcu, throttle position sensor, torque converter, transmission control unit, vehicle speed sensor
