Installing a SPC Rear Camber Kit and Toe Bolts on an Inifiniti G35
December 10, 2009 by admin
This article will show you how to install a SPC rear camber kit and make modifications for Toe bolts. TOE BOLTS: Tools used: 19mm socket 17mm socket breaker bar 2 socket wrenches sharpie Dremel #115 dremel bit Jack & Jack Stands Jack the car up and place jack stands. Loosen stock toe bolt. Using hydraulic […]
Filed Under: G35-G37 Articles, Product Review Tagged With: cars, G35, how to, infiniti, install, nico, Nissan, SPC rear camber kit, toe bolts
The New Nissan Z Proto
