1991 240sx Coupe : NICOclub Ride of the Month | rico05
1991 240sx Coupe – Owned by Rick Novak (rico05) Car: 1991 MS13 SE Coupe Interior Mods: Peyton wood steering wheel Nismo carbon horn button Nismo resin “dildo” shift knob Autometer Ultra-Lite Pro Comp water temp/boost gauges 180SX (JDM) throttle pedal (closer to brake pedal) HKS E-01 turbo timer Exterior Mods: Sleepy eyes Xenon front lip […]
Filed Under: 240sx Articles, Featured Ride Tagged With: 16" Zirgo electric fans, 1991 240sx, 1991 coupe, 1991 Nissan 240sx, ARC M070 sidemount intercooler, Autometer gauge, Autometer Ultra-Lite Pro Comp gauges, Axxis Metal Master pads, B&M oil cooler, B&M oil filer, Brembo blank rotors, Ciebe lights, Falken Azenis, Goodridge SS lines, GReddy water temp sensor adapter, HKS E-01 turbo timer, HKS HiPower Silent catback, HKS SSQV BOV, HKS SSQV recirculation kit, JDM CA18DET, JDM S13 K’s 21mm rear sway bar, K&N cone filter, KA24E MAF, KA24E throttle body, Koyo R1276 aluminum radiator, Manaray VS12, MBC at 10psi, Megan Racing toe links, Moroso 1/8NPT inline adapter, Nismo Adjustable fuel pressure regulator, Nismo carbon horn button, Nismo oil cap, Nismo radiator cap, Nismo resin “dildo” shift knob, Nismo S-Tune coilovers, Nismo strut tower bars, nissan 240sx, Peyton wood steering wheel, Piping Pro polished aluminum intake pipe, ProjectSilvia RUCAs, ProjectSilvia traction control rods, Rigid Racing radiator panel, Sleepy eyes, SLP subframe collars and spacers, SR Garrett T25G, Tein inner and outer tie rods, Top Speed front traction brace, Walbro 255 Fuel Pump, Whiteline endlink bushings, Xenon front lip, Z32 fuel filter
1991 Nissan 240sx NICO Forums Ride of the Month for April 2008
       James Sisson (PapaSmurf2k3) 1991 Nissan 240sx I originally purchased my 91 240sx back in 2002. I was 17 and my first car was a 1987 Nissan Maxima that I picked up in non running condition for $100. I learned a good deal about car mechanics on that car, and it was pretty nice (power […]
Filed Under: 240sx Articles, Featured Ride Tagged With: 180sx VLSD, 1991 240sx, 1991 nissan, 1991 Nissan 240sx, 2 10" kicker subwoofers, 225/45 Toyo Proxes, 240sx automatic brake booster, 3" exhaust, 300zx Brake master cylinder, 300zx front brake conversion, adjustable fuel pressure regulator, APS HFTO turbine outlet adaptor, Blaupunkt speakers, Blow Through Z32 MAF, Centerforce Dual Friction clutch, clutch box removed, EGR delete, eibach pro kit springs, Greddy Profec E-01 boost controller, hardened NISMO wheel studs, JGS DIY manifold, Kenwood 600W 2 channel amp, Kenwood head unit, Konig Monsoon 18" wheels, KYB AGX struts, Magnaflow resonator, nissan 240sx, NISTUNE ECU 550cc injectors, SPL tension rods, Supertech 9:1 pistons, TD06 23G turbo, Walbro fuel pump
