Applied Vehicles: Infiniti vehicles, equip. with AFS Difficulty Rating:Not Applicable Estimated Labor Time: Not Applicable Estimated Total Cost: Not Applicable Find related tutorials and information on your vehicle in NICOclub’s Nissan Forums & Infiniti Forums The 2011 Infiniti Consumer Safety & Air Bag Information Guide provides information for 2011 Infiniti vehicles available at the time […]
Reset SRS Airbag Light on a Nissan Maxima
How to reset SRS(air bag) light: Open the driver’s door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver’s Door Switch (DDS). Turn the ignition from OFF to ON. Press the DDS at least 5 times […]
Maxima and I35 Airbag light reset procedure
This worked on my 2002 I35.I don’t know if it’ll work on other similar model years or not. I am pretty sure it will NOT work on anything older than 2002, and it probably won’t work on anything newer than 2004. Again, it worked on my 2002, and that’s all I know. First, turn on […]
