Here’s a write-up on how to troubleshoot and repair the HVAC “Fan Amplifier” module, as used in G50 (1990-1996) and FY33 (1997-2001) versions of the Infiniti Q45, the A32 (1995-1999) version of the Nissan Maxima, and probably other models as well. This thread is the result of repairing dead fan amplifiers from IrvingQ45 and goody94q45, which they […]
Nissan Maxima – How To Install Rear Wheel Spacers
This How-To was performed on a 5th-Generation (2k2) Maxima. Installation should be similar to other Maxima generations as well. Special thanks for this write up goes to Fezzik (David Honey). Posted with permission from the author. This is going to be a simple How To for the H&R wheel spacer on the rear. When you […]
Nissan Maxima – How To Program Remote
I recently had to replace my remote, but I was unable to find anywhere on the Web the instructions for registering the remote unit with the car’s computer. I eventually obtained the following instructions from an Infiniti Dealer and I have posted them below. 1.Get in & lock the doors2.Insert the key into the ignition […]
Reset SRS Airbag Light on a Nissan Maxima
How to reset SRS(air bag) light: Open the driver’s door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver’s Door Switch (DDS). Turn the ignition from OFF to ON. Press the DDS at least 5 times […]
2002 Nissan Maxima SE – NICOclub Ride of the Month September 2006
-Ruff Racing 18″ x 7.5″-Yokohama AVS-DB S2 235-40-18-Eibach Pro-Kit springs -Addco RSB-FSTB-Tokico Illumina’s-Injen Intake-WarpSpeed exhaust-Eurolite Fusion high beams-PIAA Ion Crystal fogs-PIAA Super Plasma parking lights-PIAA Super Plasma reverse lights-Hella SuperTone horns-Pioneer DEHP4800MP headunit-Precision Power PAR-225 Pre-amp-AudioControl 24xS crossover-a/d/s PH15 amp-Alpine MRP-M450 MonoBlock-Infinity 12″ sub (will be JL again soon)-MB Quart MusiComp crossovers-JL XR650-CSI components-2ea 1-farad […]
NICOclub staff – audtatious
Staff Bio’s >> Matt (audtatious) Administrator / Web Design Idiot Background: I initially started playing with car audio in 1982 while in high school. My first car was a 1979 Toyota Celica which had both stereo and performance mods (Header, lowered suspension, rim/tire upgrades, and Kenwood stereo system). Second car was a 1978 Cutlass w/built […]
