Infiniti Q45 Rough Idle Diagnosis
December 10, 2009 by admin
Resolving Rough IdleBy Jesda Gulati Fuel Injectors – Bad gas or regional mixtures tend to result inearly injector failures. A fuel smell in the cabin also hintsat injector problems. Non-OEM injectors are not recommended.Learn how to test your injectors Fuel System- Purchase a can of BG44kfrom Infiniti of Scottsdale and add it to a 3/4 […]
Filed Under: Q45 Articles Tagged With: crank angle sensor, fuel injectors, fuel system, infiniti.q45, injector problems, mass air flow sensor, o2 sensors, oxygen sensors, throttle body, throttle position sensor
The New Nissan Z Proto
