Resolving Rough IdleBy Jesda Gulati Fuel Injectors – Bad gas or regional mixtures tend to result inearly injector failures. A fuel smell in the cabin also hintsat injector problems. Non-OEM injectors are not recommended.Learn how to test your injectors Fuel System- Purchase a can of BG44kfrom Infiniti of Scottsdale and add it to a 3/4 […]
2004 Nissan 350Z – NICOclub Ride of the Month September 2005
ATI ProCharger w/ 9psi pully Shielded CAS wire Custom Grounding Kit AAM Y Pipe High flow Cats J&S Ultra Safeguard AAM ECU reflash B&M Short Shift Kit GReddy AirFlow Plate EGT Gauge in Drivers door AC vent Plenum Spacer Greddy Oil Catch Can Koni 8241 adjustable shocks Greddy Blowoff Valve 2004 Nissan 350Z – Owned […]
