G35 Bulb replacement stock part numbers
Low beam headlampHID-D2R High beam headlamp9003 Parking light168 Front turn signal7440 Rear turn signal7440 Tail lightLED Stop lightLED High mount stop lightLED Fog/Driving light9003 License plate168 Back up light921 Front sidemarker194 Rear sidemarker194 Map lightDE3175 Dome lightDE3175 Step/Courtesy lightDE3022 Trunk/Cargo area158
Filed Under: G35-G37 Articles Tagged With: bulb replacement, cargo area, courtesy light, dome light, fog, G35, high beam, how to, infiniti, license plate, low beam, map, tail light, turn signal
Custom Tint on Maxima tail lights
1. Remove tail lights by pulling back the trunk liner, after removing the retaining clips, and tail light housing nuts, on the inside of trunk. You may have to push your lenses out from inside the trunk with your hand because of the weather seal on the back side of it. If you get the […]
Filed Under: Maxima Articles Tagged With: blackout, how to, maxima, Nissan, tail light, tail lights, tint
240sx All-red S13 Taillights
This is a cheap and easy modification that will improve/update (depending on your opinion) the look of your taillights.
Difficulty: *
Time: Less than 1 hour
Cost: ~$8
Materials:…
Filed Under: 240sx Articles Tagged With: 240sx, s13, spray paint, tail light
